メインコンテンツにスキップ
CDMA iPad 2モデルの第二世代は16、32、64GBのオプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1397です。修理は細かい作業が含まれ、熱で温めてこじ開ける作業が必須です。
20回答 すべてを表示
I replaced the screen on iPad 2 and I received a Black screen!
I replaced the screen in iPad 2,3.
After that I received a black screen.
The screen is completely black as when is off.
when I turn it I have the same screen. I don’t have illuminated light. Black complete as when is off!
i checked the LCD is working with another iPad so it’s not the LCD. Also I opened the motherboard and I saw that
I there is a blown fuse. Please took a look the picture.
Can we say that this fuse was blown??? Could somebody confirm it?
could be if I replace it will began to work????
Any suggestions will be highly appreciated!
thank you
Vinnie Venkov
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
No picture. Did you disconnect the battery before you unhooked the lcd and digitizer? It sounds like you shorted the backlight circuit.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you Allan. Also I"m sorry for the picture, now You can see it. I had a problem to upload the picture thats why wasn't there. So do you thing this could be a problem on the picture. Also pls give advise if You know where I can buy all those small parts fuse, transistors etc, if You know. Thank You so much for Your help!!!
さんによる
コメントを追加
回答を追加する
Vinnie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 72
