メインコンテンツにスキップ
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
857回答 すべてを表示
Rode over hose and now it won't go into gear, forward or back
My husband ran over a hose with the Craftsman 4500 ride on mower and no it won’t go into forward or reverse. We can’t see if there is something disconnected, I’m not even sure where to look.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
REF: https://data2.manualslib.com/pdf2/50/497...
Above is the manual for you mower. This answer assumes that “won’t go into gear” means you can move the control lever into reverse, neutral and forward but the mower doesn’t actually move in those directions. If this assumption is wrong, and you can’t move the control lever itself, then you have a problem in the lever linkage or the transmission.
Most likely your drive belt has either broken or come off the pulley. Pages 24-25 in the above manual shows the installation of the belt (“To Replace Motion Drive Belt”). In layman’s terms… Look under the mower right below the engine (It helps to drop the mower deck to its lowest position). You should see a shaft coming down with two pulleys attached (see Page 24, Item “M” in the Figure). There will be a small pulley towards the top of the shaft, and a larger pulley at the bottom of the shaft. You want to inspect the belt that goes around the top pulley - it should be tight. If the belt is broken, you will need to replace it. If it is loose, then you need to check the belt routing on Page 25, and make sure it didn’t come off one of the other pulleys. If the belt is routed correctly and still loose, that means the belt has stretched and will need to be replaced. Hope this helps.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Susan Disbrow さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 7
過去 30 日: 11
今までの合計 126
