Can I use an iPhone X battery in my iPhone XS safely
iPhone XS replacement battery is quite expensive compared to the iPhone X can I just use the iPhone c battery in the Xs
この質問は役に立ちましたか?
この質問は役に立ちましたか?
They are very different designs!
The XS uses a newer single cell were as the X uses a dual cell. The charging logic is very different as the X uses a double tap where the XS uses a single tap. Your logic board is not designed to support the other battery charging needs. Please use the correct battery for your phone!
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 24
過去 30 日: 103
今までの合計 8,996
