メインコンテンツにスキップ
Repair guides and support for Trio tablets on the Android operating system.
128回答 すべてを表示
charger for g5 7.85!
need a charger for G5 7.85
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
After looking up your tablet, it seems that a connector called a microUSB should work. chances are, you might have one lying around your house!
They look like this:
Alternatively you can buy one by searching up MicroUSB cable. Heres one on amazon:
https://www.amazon.com/AmazonBasics-Male...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You may need a high amp charger in the 2-3A range, as this is a larger device. Any MicroUSB cable will work, but oftentimes with tablets your phone charger does not cut it. Try and find a 3A one to be sure - it may be excessive, but the tablet will only draw what it needs and you can use it with high powered devices no problem. It doesn’t say what it needs on the back (which some of these cheap Android tablets do), so I would assume 2-3A as the baseline.
Try and find a charger like this. Chargers last so long it makes sense to spend more on a good one, even for a low end tablet. The tablet will fail before a quality charger.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
deberryjr1955 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 33
