Can't connect to my cell phone network
i replaced my charger daughter board, and idk what i did but once i was done my phone wouldn’t get service, ive tried everything i can think of short of a factory reset and im out of ideas
Cellular communications to & from smartphones depend on SIM cards to work. Is your phone's SIM card securely in its slot? It may have been bumped out of place when you replaced the daughterboard.
このアンサーは役に立ちましたか?
it's detecting the SIM card, and it's secure from what i can tell, on a whim i swapped the old board back and it started working again but i still have no clue what's going wrong
If the old board works but the new one doesn't, the problem may be that the new board is either defective or incompatible with the phone.
Are the two boards made by the same manufacturer? Sometimes different manufacturer models produce different results, and it's best practice to replace a board with one made by the same manufacturer.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 58
