Why do my fans not spin?
So I've built my first PC, got it to post, currently installing Windows and the CPU-Fan is doing his Job. But my Case Fans just don't spin. I couldn't spot a mistake with the Cables so what could it be?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
If you have the motherboard manual check that you have connected the chassis fan(s) to D and or E as per the diagram on p.1-18
Then go into BIOS and set the Q-FAN Control for CHA1 Fan and or CHA2 fan, depending on what type and which fans you have connected as per p.3-7 (see p.3-3 for how to get to the Q-Fan Control in BIOS)
このアンサーは役に立ちましたか?
Thanks for the help, that actually worked!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 2,236
2 件のコメント
Hi,
What is the make and model number of the motherboard?
jayeff さんによる
The Motherboard is an Asus ROG Strix. The Model-number is ROG Strix X570-E Gaming
Mutz さんによる
