MacBook Pro 15" Core Duo Model A1150
Ok so here is my problem...
I replaced the dvd drive the top case with keyboard and outside top case. And now my mbp a1150 1.83 GHz wont start or make any noise at all just nothing. the magsafe light stays green always even with the battery on and the battery has a charge. I've check everything the ribbon cables for the track pad all are connected. the display is connected all screws are in place. I tried to short the pins on the logic board and nothing happens. I really need help ASAP this is my only laptop and is the one I use for my business. Any suggestions, tests are welcome.
この質問は役に立ちましたか?
6 件のコメント
I tested with a MM and it has voltage 3.3 volts
Shogun さんによる
What has a voltage of 3.3 volts?
rj713 さんによる
the pwr pins
Shogun さんによる
I also checked the memory it well connected
Shogun さんによる
Do you have the 85w power adapter?
rj713 さんによる
1以上のコメントを表示
