Battery for 13" MBP Retina mid 2018
Is the MBP 13” Retina w/Touchbar battery the same as in the same MBP but from mid 2018? If not, does anyone know where to get a replacement battery for the latter device?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I’m surprised you need a new battery for this system already. Can you tell us a bit more on why you need it. Maybe we can offer a cheaper and easier solution.
The battery is just becoming available from recycled systems 18/19 13” MacBook Pro Touch Bar Battery, Used Apple P/N 020-02497 & Battery marking A1964. The sources I use don’t have them new yet.
Here’s the 2017 guide which is the same for the 2018 & 2019 models to replace it MacBook Pro 13" Touch Bar 2017 バッテリーの交換
このアンサーは役に立ちましたか?
Thank you for the input. It's quite helpful. The battery has begun to swell, deforming the case to the point where it does not sit stable on a table top and keyboard/trackpad function is impaired. I don't see any other option than to replace the battery.
I found this: https://www.laptop-battery-shop.com/appl... which appears to be the correct replacement.
You may want to check your paperwork so see when you bought the system Apple will often give you a bit of leeway. I would first try to see if you can get Apple to replace it first under warranty.
I have this exact problem as well on my 2018 13" MBP
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 94
