メインコンテンツにスキップ
TI-84 Plus calculator support.
35回答 すべてを表示
Why is a row of buttons on my TI 84 plus not working?
I’ve got a TI 84 Plus in good condition; the only problem is that not all of the buttons work. Specifically the buttons that aren’t working are the “log”, “7”, ”8”, “9”, “x (multiply)”, and the Up button on the keypad. The first 5 of these buttons are in a row straight across the keypad. I’ve tried cleaning the key mat and the big green motherboard, still nothing. There was some yellow gunk on the board when I cleaned, there might have been a battery leak at some point maybe? Any help would be very much appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If a whole row is dead then it’s likely the issue is a broken trace on the PCB. If you have a multimeter then you can probably pinpoint the place(s) where it’s broken and repair it if you know how to solder. There are many tutorials out there for fixing a broken trace, here is one I found. Let me know if you have any other questions!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Micah Yoder さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 16
今までの合計 430
