メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
iPhone 4 reception loss due to loss of copper clip?
Hi guys, below is an image of the iPhone 4 logic board. Recently while taking the logic board out the copper part circled fell off and now the iPhone has no signal. I was just wondering how much that would effect the overall gsm signal?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
最も参考になった回答
A lot!
Wireless and GPS too will have less and less Signal.
I lost that too due to a non authorized service point (the guys who think that the producer has put that part for fun there) and I ended up taking the phone to Apple for exchange!
Find the clip and put it in it's place if you want to have an operating phone!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Mine was broken as well while removing the logic board, I welded it back.
It works fine
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just broke something on the main board... I can't get the signal ! Or when I get it, it's only for a few seconds, than it drops down to no signal... I broke the tip just beside at the right the little pointed thing on the image... tryed to glue it but it seems worst... it's still on guarantee but I played with it, I changed the frame for a new one because it was folded due to a truck passing on it, well, do you thing they would echange it anyway ? When they exchange it, do they tear it down before exchanging ?
Thanks !
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It's all up to the discretion of the genius that you are dealing with. Sometimes they will take off the rear cover to make sure all of the LSI's are still intact and that there is no evidence of tampering and sometimes they will take on look at it and put a replacement in your hand within 10 minutes. I have taken my phone in for a replacement (iPhone 4) twice, both times i had tampered with it and both times i got a replacement no questions asked. Some people say differently, its all up to the luck of the draw.
さんによる
コメントを追加
I just lost the clip. Is there a way to purchase a new one?
I looked all over for it and could not find a way to buy it? Doe it have a special name to look for?
Thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Signal problems can also be related to damage to the blue inductors on the board. They are near the antenna connector. Check here
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,444
