My refrigerator is too cold
Everything in the refrigerator seems to be freezing. All my vegetables such as lettuce, carrots and others are frozen.
If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher.
This failing we may need to look at the damper and/or damper control and for that we would need your make and model number.
このアンサーは役に立ちましたか?
Locate the temperature dial in the refrigerator and turn down a few clicks
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 43
1件のコメント
Hi,
What is the make and model number of the refrigerator?
Does the compressor motor seem to be continually running?
jayeff さんによる
