How do you remove a hard drive & battery?
how do you remove the hard drive & battery from a dell inspiron 9100 laptop ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here is a link to the service manual for your computer. Use the" before you begin" for info on removing the battery. Good luck.
このアンサーは役に立ちましたか?
Battery is easy to un-clip. Turn over your laptop and you will see a lock at one side of battery all you need to is just to slide that downwards and pull the battery upward.
For take the hard drive off it pretty easy, have a look at sound card side your will see a screw at the bottom, all you need to do is to open that screw and pull the separate part outward it shall bring your hard drive off.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,819
1件のコメント
This question was migrated from http://meta.ifixit.com/Answers.
iRobot さんによる
