メインコンテンツにスキップ
The Ford E-Series (also known as the Ford Econoline and Ford Club Wagon throughout various stages of its production) is a range of full-size vans produced by Ford Motor Company.
21回答 すべてを表示
Fan belt jumped of pulleys
2000 e-150 4.2 v6,61k on it. I got the belt off and looked at the pulleys. I found that the automatic belt tensioner pulley seemed froze and also tried to do counter clock wise and bring it back off tension and it wouldn’t move either. A littel w-d and got it working. my question is should I replace the whole mechanism or can I just replace the pulley by itself? also I guess I should replace the idler pulley since I’m in there. Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Yes replace the complete tensioner assembly. And it couldn't hurt to replace the idler pulley while you are doing it. You should also check the belt at the same time. It might be better off to replace it also.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks so much for your advice, Yeah the pulley is bad on the tensioner, now its a matter of getting the bolt unfrozen on the unit itself.
さんによる
コメントを追加
Yes get new belt, tensioner and idler.
WD-40 isn’t a lubricant its a water displacer.
A good lube/solvent is 75% automatic transmission fluid with 25% Acetone.
PB Blaster works, Zep 45 works, Liquid Wrench works too.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Greg allen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 41
