How to remove broken glass?
Hello,
The glass of my touch 4g broke, and i was wondering how i am going to remove tiny bits of glass of the screen? Becouse i think the tiny glass bits will stick to the panel.
この質問は役に立ちましたか?
Hello,
この質問は役に立ちましたか?
the tiny bits of glass tend to stick to the adhesive holding the glass panel in place. I'd wear safety goggles/glasses etc as sometimes despite your best efforts something flicks up. When you scrape the adhesive off the glass will come with it..it's very sticky.
このアンサーは役に立ちましたか?
Thanks, i'll get the glass tomorrow, wish me luck!
The front panel is glues onto the screen so you need to get a new one And its expensive
このアンサーは役に立ちましたか?
Use a heatgun to remove the glass, the tricky part is reattching the new screen after you get the old one off. The connection faces the back of the device instead of the front so you have to remove some screws and do alittle bending to get it in there. I had these guys fix a few for me in the past, they did a pretty good job. www.HookUpCellular.com
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,077
