Bad SSD? Or overheats? Freezes after clean install of OS High Sierra.
Hey Guys,
I have a bit of a problem with my 2009 27” iMac.
It has been shutting down halfway through botting up. I then booted into recovery mode and was able to do a clean OS install on the iMac then booted up no problem.
Then as I use it, the iMac just freezes (but the mouse still works) and I won’t be able to do anything until I force reboot it.
Sometimes, there are some graphic distortions onscreen (only during boot up), could this be due to overheating?
I’m considering changing out the SSD as this might be the problem?
Any suggestions would be much appreciated! Thanks
2 件のコメント
Who's SSD did you install? Make and model
Dan さんによる
This is the info on my SSD
INTEL SSDSC2MH250A2:
Capacity: 250.06 GB (250,059,350,016 bytes)
Model: INTEL SSDSC2MH250A2
Revision: PWG4
Serial Number: LNEL127400QA250DGN
Native Command Queuing: Yes
Queue Depth: 32
Removable Media: No
Detachable Drive: No
BSD Name: disk0
Medium Type: Solid State
TRIM Support: No
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. status: Verified
johnson yu さんによる
