メインコンテンツにスキップ
The first generation Honda CRV, produced from 1995 to 2001.
97回答 すべてを表示
How to drain out engine oil
Any video clips to help me out of my problems
  1. CRV RD1 has the oil filter or not
  2. how can i drain out and replace my engine oil. Honda CRV-RD1
  3. i already replace my reverse bulb with new bulbs but still reverse bulb not turning on when put on reverse.
  4. Engine to weak and pick up late to speed
  5. oil league side of my engine,where of the engine to fix it from this league
  6. any other fluid i can use to clean side my engine
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Not a video but here is a compilation image, taken from the service manual on how to change the oil and the oil filter in a 1997-2000 Honda CR-V
(click on image to enlarge for better viewing)
Here’s an image that shows the electrical wiring for the reversing lights which may help.
Get the OBDII port scanned for any codes to find out what is wrong if anything with the engine.
Any engine degreaser should help to clean up the outside of the engine.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Hertz Hou さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 59
