メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
480の回答 すべてを表示
MacBook Pro Late 2013 unable to write to ANY external media
Weird one.
My MacBook Pro, Late 2013, is unable to write to ANY external media. Anything that is plugged in (by which I mean SD cards or USB drives) comes up on the desktop, I can read file contents, but cannot write. No matter which port I plug it into.
I have tried the media on other (various) devices (iMac, MacBook Air & another Pro) and it works everywhere.
I have created a new user, and tried there- no luck.
I have tried to alter permissions on the drives, but they say I should be able to read AND write.
Help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
2件の回答
Go into Disk Utility > Disk First Aid select your external USB drive did it find a problem?
After you’ve copied off the data on the USB drive go into Disk Utility again and this time reformat the drive to GUID Journaled file system afterwards see if you can then write to the drive.
Also what macOS are you running? And if you’ve got any antivirus apps running and if they are all upto date?
Update (04/29/2020)
Sadly, this is starting to sound like a PCH level problem. A rare one for sure!
Apple no longer offers a block diagram in many of its schematics so this is just for reference. In this series the PCH is part of the CPU package
As we can see all of the USB connections go the PCH logic! Time for a new logic board.
この回答は役に立ちましたか?
スコア 1
コメント:
It began when a new SD card I bought couldn’t be written on, and yes- that was when I tried first aid and formatting it in Disk Utility. Neither worked, it errors out.
The same drives are in perfect health according to other machines. [br]
No antivirus, OS X High Sierra.
さんによる
コメントを追加
最も参考になった回答
If the read works, there is nothing wrong with hardware.
When in doubt, reinstall OS.
Or it could be just you were trying to write to a NTFS volume on a Mac, which is not supported natively.
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
pabz さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 16
