メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
773回答 すべてを表示
Battery compatibility. A1494 vs A1618
Hi.
I cant figure out the compatibility of macbook battery in the late 2013 - mid 2015 A1398 models.
Will a battery with model number A1494 fit a 2015 A1398 MBP? Or will i need a newer battery with model number A1618?
Some sites / vendors says the A1494 will fit, some says it does not. I get the difference in the mAh. 8440 mAh in A1494 and 8740 in A1618.
Can anyone clarify?
Thanks a lot!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
ベストアンサー
If you review the iFixit batteries
MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery
MacBook Pro 15" Retina (Mid 2015) Battery
You’ll see the power values are different!
While Apple did stick with the same dimensions and the connection to the logic board is the same for both. The chemistry of the batteries is different as such the charging rate programed in micro-controller and SMC what match up properly. I suspect some of the battery failures we have seen are do to the wrong battery being used.
MacBook Pro 15" Retina (Late 2013-Mid 2014) Batteryの画像
製品
$89.99
MacBook Pro 15" Retina (Mid 2015) Batteryの画像
製品
$109.99
このアンサーは役に立ちましたか?
スコア 4
9 件のコメント:
I see, Thats probably quite relevant.
thanks for the reply Dan!
さんによる
@ajes - Don't forget to score the answer and accept it - Thanks!
さんによる
@danj - From late 2012 when new type of battery was introduced and apple started glueing them in, is calibration not required anymore? And if not why is this when "old" types in 2010 - 2012 did need it.
Better monitor software or different batteries?
Calibration = Charging battery full 100% + 4-5 extra hours, draining bat through normal use and charge again.
I have replaced battery in some A1278 sometimes the replace battery message comes within a year and a calib + SMC reset usually helps.
さんによる
I calibrate the batteries I put in. Apple still does it as far as I know, so I have no idea why you think it's not done.
Calibrating a battery later doesn't really change things. All you are doing is resetting the high and low water points, over time they will drift back to where you had them before you re-did the calibration. Yes, it does appear to improve things but at the risk of overheating your battery.
さんによる
Hi Dan and Anders
Would it be possible to use the A1618 battery (with 99Wh capacity) in a Macbook Pro 15 Retina Mid-2014 that's originally fitted with a 95Wh battery?
さんによる
4件以上のコメントを表示
コメントを追加
Actually, the power rating is showing up as 99Wh in both of those links. I don't know if it is a recent typo.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anders Laursen さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 83
今までの合計 4,158
