MacBook Pro suddenly shutdow never turned on
i was trying to clean dust on the Macbook pro, it suddenly shut down then never turned on. i know there was more than 50% battery left when t shut down. it is not even charging when i plugged on. my charger is new and working fine. i already tried to plug on different outlet. nothing happens, is no sign, completely dead. i know my internal battery was showing week but still i was able to work for around half an hour without connecting the power.
Did you properly disconnect the battery before you starting dusting out your system as well as practice proper ESD precautions?
Dan さんによる
my charger was not attached. i was just cleaning outside not inside/
jaga さんによる
Did you use a spray cleaner?
Dan さんによる
