メインコンテンツにスキップ
General repair information on LG washing machines.
12回答 すべてを表示
Why is my machine getting an OE error between each cycle
Hi, my LG front load washer/dryer won’t complete a full wash. It stops with an error message ‘OE’ at the end of the washing cycle, I then turn it off and change it to rinse and spin only and it rinses but then same thing happens at the end of the rinse cycle and so on. Obviously something wrong with the drainage, no kinked hose, clean filter and the pump is working because it will drain the water away once turned off and the cycle changed manually to the next step. Is this an issue with the computer….?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I’m having the same problem. I’ve replaced the drain pump, inspected all the lines, and replace a couple of valves already, but nothing has worked.
I see this happened to you almost 2 years ago. Did you figure out what was causing it?
Hopefully this will help me with my issue.
Thank you
さんによる
コメントを追加
2件の回答
最も参考になった回答
OE error code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks Mayer. Yes I googled it and checked both of those things, they're fine. Also, the water will empty once the machine is turned off and on again and set to the next step manually.
さんによる
コメントを追加
@lauren_h since you already checked the obvious it is time to dive in deeper. Could be a drain pump issue as well as a main circuit board. Check this out next
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
LaurenHollingsworth さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 115
今までの合計 2,315
