メインコンテンツにスキップ
2009年6月発売、2.66, 2.8, もしくは3.06 GHz Core 2 Duo Processor
300回答 すべてを表示
Replace Now! But low cycles and 100% charge
I recently picked up a 2009 MacBook Pro 15”. El Capitan is telling me to replace the battery now. Although the battery is at 100 percent and only has 257 cycles on it. Is it really a battery issue for why the MacBook is shutting down after a few seconds (sometimes minutes) without it plugged in? Or is it something else? I also gave a third party application saying that the battery has about 4 minutes left(and going up for some reason), 10.8 years old, the original max is 6500 mAH, the current max is 65035 mAH, and the current charge is 65035 mAH. This app has never done this for me, so I’m not sure what’s wrong.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Let’s try a different Battery App. Please download, run and post your results using Coconut Battery
https://coconut-flavour.com/coconutbatte...
UPDATE 4/26/20
Something is very wrong with what this battery is reporting. Although it does have a low cycle count, it is 11 years old (a long time for a laptop battery). I’d go ahead and replace it and hope there is nothing else wrong with the machine.
MacBook Pro 15" Unibody Mid 2009のバッテリー交換
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I can’t, because it doesn’t have the latest os
さんによる
I got it, new picture is up
さんによる
Okay I just ordered one and will update you when I replace it! Thanks!
さんによる
コメントを追加
回答を追加する
EJOE 123451 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 132
