メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1505の回答 すべて表示
My phone continuosly displays the apple logo, after moments of charge?
After charging the Iphone, the apple logo continuously appears and disappears. Why is the phone locked in this mode? No error codes come up. Changed the battery and the phone is doing the same thing. Can't shut the phone down with the power button.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
3回答
選択されたソリューション
you are stuck in recovery mode? does itunes recognise your phone? if not i believe this is something to do with the power management chip...it isn't functioning fully to allow your phone to boot up to full working order. The error code only appears if you try to restore your phone in itunes...it will most likely be an error in the 20's.. you can have that chip replaced by a good repairman.
see what happens if you try and restore..you could try iReb or tinyumbrella to see if that will help get you out of the boot loop
この回答は役に立ちましたか?
スコア 2
コメントを追加
i have a same situation. It was a new iphone 4, just bought it from Singapore & without any ios inside. The Apple Store guy told me to restore by ourself. I tried many times but in vain.
My situation is the Apple logo just appears & reappears after couple seconds. If i'm not mistaken, it is called Apple boot logo loop, which can't allow me to boot up or even restoring/updating. When i tried to restore, it just appeared this Apple logo repeat & repeat, not allowing me to install the ios. It is because the iTunes said "Preparing to Restore" for liked forever!
Hopefully there is a kind soul who can help me to fix it. I live in East Malaysia, by the way. It is not that easy for me to go to Singapore to change it...
この回答は役に立ちましたか?
スコア 0
コメントを追加
have you tried hard reboot? press and hold home button + power for 15 seconds until you see the apple logo. release the home and power button if you see the apple logo, and wait till its boot. hope it helps.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
stcbllng276 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 25
今までの合計 5,564
