メインコンテンツにスキップ
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
98回答 すべてを表示
Mac sees the 20" Cinema Display but display is black
The Cinema Display’s Indicator light is also black. The mouse of my MacBook Air 2017 disappears to where the monitor should be so the computer is seeing it, but the display otherwise appears dead. Is it time to give up on my old friend or is there a repair?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I think its wise to get a new monitor as you can get a larger screen with better image quality for around $200 used.
This display uses CCFL’s and uses the older dual-link DVI connector system which besides being clunky won’t support 4K or 5K if you really want to push things.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I’ve ordered a replacement monitor but I am still interested in trying to fix the Cinema Display. I’ve found similar issues in similar threads that indicate the fix may not be too expensive but I’ve not found enough detail to attempt a repair or order a part.
さんによる
I did a bit of looking for the likely needed parts. I'm sorry to say I just couldn't find any. The only thing I can suggest is searching the used displays to see if you can find one for parts.
さんによる
コメントを追加
回答を追加する
Keleigh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 118
