320 Gb HDD from Toshiba
iPod Classic (new one) will accept Toshiba 320 Gb HDD?
What about this: http://www.amazon.com/Apple-iPod-classic...
この質問は役に立ちましたか?
評価: 1
If you are thinking about using the Toshiba MK3233GSG in your ipod, then the answer is no. It will not work because it has SATA interface. The 320GB is a dual-platter one, that means that the interface wont fit and it has different mechanics as well . The HDD for the 160GB iPod is 5mm thick and the 320 GB is 8mm. Hope this makes sense. Good Luck
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,339
need more information on the 320GB. What is the drive number? What is the interface....your ipod is a 6th gen classic?
oldturkey03 さんによる
Thank you. What about this:http://www.amazon.com/Apple-iPod-classic...
Ted さんによる
If your question is if this one will accept the above drive, then the answer is no. Same problem.
oldturkey03 さんによる
Thank you verry much.
Ted さんによる
You are welcome, good Luck
oldturkey03 さんによる
