Fix broken Digitizer Seal or replace it?
I am in the process of repairing an iPod Touch 2G's Digitizer. What is the best way to do it Replace the entire Digitizer or replace the rubber frame under the glass?
you just change the Digitizer . this is little hard as compare to if you get the touch with the rubber panel then its very easy to take out the old one and place the new one there . see this is the way to change the front panel
iPod Touch 2nd Generation Front Panel Replacement
after removing the front panel :
2 step is to Like the changing the touch of IPhone (3g or 3gs) :
iPhone 3GS Front Panel Replacement
see the step 15 directly . in that he is removing the panel from the touch .
ガイド
難易度:
中レベル
45 minutes - 1 hour
ガイド
難易度:
難しい
45 minutes - 2 hours
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,100
