iMac won't turn on
It does not work, when opening the iMac from the inside, I found that when I press the power button only the fans turn on and then turn off
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It sounds like you need to find someone to help you locally, there is a limit on what we can offer here. Where are you located? Maybe we can aim you to someone.
このアンサーは役に立ちましたか?
I'm in Palestine
Unfortunately, we do not have companies that support Apple devices, but if you explain to me what are the causes of this problem and what is the solution, I can try it myself or send it to someone who has little experience, but we need someone who explains to us what caused this problem
Sorry that's just not possible, I would need the system to diagnose it which is just not practical as I'm on the other side of the world!
thank you man
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 46
1件のコメント
Your previous posting: iMac won't turn on
Dan さんによる
