メインコンテンツにスキップ
A2115 / 2019 / プロセッサ3.0 GHz 6-core i5, 最大3.6 GHz 8-core i9. 発売日は2019年3月19日
129回答 すべてを表示
Help with my keyboard woes, please?
This computer (and the keyboard that came with it) is only 4/5 months old.
I noticed my V key was sticking. Since I’ve used Mac for a while and had to clean and reattach keys before, I figured I could do it again. I took the key off and cleaned it but when I attempt to replace it, it stays stuck down. It will not bounce back up. Like an imbecile, I took off the neighboring key to see if I could figure it out.
Long story short….I now have two keys off that I can’t put back on correctly. Does anyone know what I did wrong and how to correctly reattach? Videos I watched on YouTube do not have the clips oriented the same as the keyboard I have now.
Keyboard model A1644
Bluetooth
Compact
Thank you in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
Which keyboard do you have? I assume it's a real Apple unit
● Is it USB wired or a Bluetooth?
● Is it a compact model or the Extended model with the number pad?
If you're not sure take a picture and post it here, there should be a model sticker on the bottom iFixitでの質問に画像を追加する方法
さんによる
@danj Done. Thank you.
さんによる
コメントを追加
1 件の回答
Review this guide iBook, PowerBook & MacBook Keycap removal & fitting
If you think you have a broken part here’s a good source for the needed part Magic Keyboard keys
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
Thank you for the help, but that is not the same type of clip used on my keyboard. It is a different shape. I will see if I can get a good photo of it.
さんによる
@tink78 - Take a look at this Apple Keyboard Key Repair Guide Magic Keyboard A1644 MLA22LL If you look on the back side of your keyboard it will have a label which would be useful to know.
さんによる
@danj I added pictures of the back for you.
As for the link, I followed that tutorial but it didn't work. The key still stays stuck down.
さんによる
@tink78 - Your second image of the back side with the model number was what was needed A1644
さんによる
@danj That information was in the post. Thanks!
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Sara さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 169
