メインコンテンツにスキップ
2018年4月に発売されたHuawei の最新モデルスマートフォンです。モデル番号はCLT-L29。
56回答 すべてを表示
Data recover from a phone with black screen(broken screen)
I have a broken screen on huawei P20 pro. The device has a broken screen and the screen i black. So i cant see anything or touch the screen. I want to recover the data without replace tha screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント:
I have the same issue , i cracked my p20 pro’s screen yesterday. It’s all black I can’t see anything on screen but the phone is working , my whatsapp web is working , i hear notifications also I can use my google assistant feature with my freebuds. I will send my phone to Huawei Service to replace the screen but they told me that all of my data will be deleted in this procedure. I need to find a way to store my data. HiSuite is not working since I have to give permission from my phone to use it , and I can’t give because I dont see anything.
Please help us
さんによる
where you able to recover your data???if yes, what did you do?
さんによる
Huawei doesn't cater for this kind of thing. I consider it poor planning equals poor performance. Every device should be repairable cheaply, and then we wouldn't keep having to have new stuff. 1 gram of some of the Rare earth materials in electronics equals 100 tonnes of acidified rocks! Pollution of children! Slave labour! For god sake no wonder we have weird weather and climate change!
さんによる
コメントを追加
3件の回答
You could try to find someone with a donor device that you could hook the screen up to. Either way, you’ll need a screen to retrieve your data.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The easiest way is to use broken android data recovery tool, it has mehtod to detect your device. Some tools are available, such as MobiKin Doctor, EaseUS,ETC.
If this way doesn’t work for you, you should buy a USB-C OTG Hub, it will enabled you to connect the hub directly to the damaged p20 pro via its USB -C. Cable. The hub itself has an HDMI port that you can connected to your monitor and used to display your phone.  Using the mouse and keyboard ,then you would able control and access the phone via the monitor and get data back.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I tried using USB C to otg adapter but the monitor is not detecting the signal. My phone has a micro USB point. I already has a USB c to HDMI adapter. I bought a micro USB to USB c connector and then used the USB c to HDMI adapter. Doesn't work. Help pleaae!!!! Don't want to loose my kids precious photos
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stelios Karagiorgis さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 58
今までの合計 8,127
