メインコンテンツにスキップ
baterry shows 100%, yet when I unplug the power cord, it turns off
when i unplug the power cord, my computer turns off, even though the baterry shows 100%
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
I have a samung galaxy. S5 phone shows 100%charged unplug charger phones dies won't turn bk on unless charger is plugged in why
さんによる
my school computer charges to 100 so i unplug it and then it turns off and when i turn it on its on 1 percent
さんによる
コメントを追加
6件の回答
最も参考になった回答
If the battery/computer…
  • Is more that 2 years old.
Batteries are very tricky. Because you have to think of them as fuel tanks. Batteries have a capacity, and when you charge them you're refilling the tank. Although, over time after several drains and refueling. The actual capacity gets smaller and smaller. So it's charging to 100% of the very little to no capacity.
  • Has been plugged in constantly when used.
As weird as it sounds this is actually really bad for the battery. Yes, it does keep it charged constantly but batteries do have a “memory" to say the least. If a battery doesn't get the chance to deplete and refill, its at a constant state of depleting. Rather than refilling.
  • Was left unused for a good amount of time (more than 2 or so months)
What happens is the battery voltage goes below the amount needed to power the device on its own and applying the power charging source is barely putting it past that threshold for it to work as it's plugged in but not unplugged.
  • Battery is not the original and was replaced with a “cheap” replacement.
This goes hand in hand with the previous one. When batteries are made they're sent to a warehouse until sold. So they're “New" because they haven't been used but they're not charged while waiting to be sold and discharging.
Overall a new battery will fix the issue. My recommendation go to a Battery Store such as Batteries Plus Bulbs. They'll get there batteries fresh each month and maintain them as well as they'll come with warranties. You'll pay more but it's cheaper than a new laptop.
If these do not fit the criteria of your issues then I would recommend contacting the manufacturer.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Hi @tcashew
Create a Win 10 battery report to find out the state of the battery.
Even though is shows 100% it may not be able to supply the necessary power when a load is connected to it.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It may be caused by two reasons:
Update or upgrade windows 10
If you’ve recently upgraded the operating system of your laptop to Windows 10 or updated to the 1809 update, maybe this is the reason for the issue.
Faulty battery
On the off chance that your PC closes down once you unplug the connector, it normally implies your battery isn't working as expected.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well may be you need to change your battery and replace it with the new battery it might help in fixing the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the same issue and changing the battery did nothing. Still have the flashing amber light and it goes dead when I unplug it. I also changed the CMOS battery, to no avail. I think it's the motherboard. The laptop I have is over 4 years old, so I think it's past its lifespan.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I am using Linux Mint, BTW.
さんによる
コメントを追加
Ask for a new battery. The first battery that was sent was dead. The 2nd one worked.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tony Cashew さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 19
過去 30 日: 91
今までの合計 29,101
