What does appleacpiplatformexpert start:failed mean
I get the error appleacpiplatformexpert start: failed when I start up in verbose mode. Could that be a power problem with the MacBook caused by a third party unbranded charger
Sounds like you may have used a patcher to try to upgrade your system. If you have appleacpiplatform kext in your usb extensions folder, remove it, the installer should l boot normally.
このアンサーは役に立ちましたか?
I took out the hard drive and I got the usual kernel panic that I get, unable to find driver for this platform which suggests bad ram but the ram is brand new
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 147
