メインコンテンツにスキップ
2018年9月21日に発売されました。モデル番号A2097, A2098、GSM もしくはCDMA / eSIM もしくはナノSIM / 64, 256、512 GB / シルバー、ゴールド、スペースグレイ。(正しい発音は"iPhone 10 S.")
398回答 すべてを表示
Why both the cameras, front and back, and the flash are not working?
I have followed all of the online solutions to fix the software issue, such as changing the setting or restarting the phone, but none of them work. So I think its a hardware issue. Then I tried to switch out the rear camera for another. And its showing no result, still having the same black screen on the camera app. So now I’m thinking is it possible that the main connector is damaged somehow?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
There are a few things to rule out. In my past experience it would be best to test all parts so disconnect the front camera and test then the rear and finally you could rule out that. Once one camera goes usually both stop working is what i have had in the past with apple. it may be the front camera needing replacement and don’t worry you wont lose facial recognition from that.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I’m not sure but I think if one camera is not working, you can get stuck when trying to switch cameras in the app. I have seen the flashlight not work before on a phone because one of the cameras was not working. I believe it was linked to the rear camera.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vik Sirivong さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 153
