1.25 in spring strap fell out after repair.
This is a spring with 2 small mounting holes with a slotted end.
Hi @sandy430 ,
Without an image it will be difficult to identify it and where it belongs, if indeed it does belong in the laptop.
Here’s a link to the hardware maintenance manual for the laptop.
It doesn’t mention or show the spring in the parts section as a separate part so maybe you’re right and it doesn’t belong in there.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 49
6 件のコメント
Hi @sandy430 ,
The make and model number of the tablet would go a long way to getting a helpful answer
Adding an image of the spring to the question would also help.
Here's how.
iFixitでの質問に画像を追加する方法
jayeff さんによる
I added a second HD. The unit seems to work ok
John Iwaniec さんによる
Lenovo Flex5-1570
John Iwaniec さんによる
No picture. the two mounting holes appear to from a pressed mounting. It has sight hump with the slot at the other end.
John Iwaniec さんによる
I found it on the work table with the reassembly. May be from something else. Sorry
John Iwaniec さんによる
1以上のコメントを表示
