Why won't my dvd player play in color?
my dvd player won’t play in color, black & white only
Hi,
Some TVs have a shared component video (3 RCA) and composite video (1 RCA) input. If you connect the DVD with composite to the input when it is set for component you get a black & white picture. There will be a place to change to composite in the TV menu if this is the problem.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 5
過去 30 日: 11
今までの合計 2,277
What kind of cables are you using? Have you tried resetting the settings to default
Bobby Gunnels さんによる
Hi @monty1941 ,
What is the model number of the dvd player?
What type of connection to the TV are you using, HDMI, Component video (red/blue/green + red/white RCA cables) or Composite video (yellow + red/white RCA cables)?
jayeff さんによる
you might need a colourd scart adapter
John Rochford さんによる
What is a colourd scart adapter?
Slampy さんによる
