Why is my watch not pairing on my iPhone?
Hi All,
i have bought a used watch 3. The display has been changed, and i do not have it. The watch is not pairing my iphone. Can i fix it somehow? Thank you!
If the Force Touch sensor and NFC antenna was damaged and replaced during screen repair, it will not pair with a new device. Just like FaceID and TouchID components, the force touch sensor is paired to that specific watch.
このアンサーは役に立ちましたか?
Thank you! Can this be fix somehow?
Not without specials tools that only apple has
I have same issue on my S4 Watch
could you fix ?
Are you getting any pop up on your iPhone screen like pairing failed or while connecting it was unpairing automatically after sometime ?
このアンサーは役に立ちましたか?
feroz_khan77874 - The newer WatchOS looks at the NFC chip so if you've replaced the screen you'll need to transfer the NFC chip over to the new screen.
このアンサーは役に立ちましたか?
Watch OS 6 cause this
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 247
1件のコメント
Has the watch been unpaired with the old phone?
Tyler さんによる
