メインコンテンツにスキップ
A standard cordless compact DeWalt 18V drill with a high performance motor that delivers 380 watts. Equipped with easy to hold design that allows you to work in difficult spaces.
11回答 すべてを表示
Are the knockoff NiMh batteries any good?
One of my two DC970 batteries are at the end of it's life (6.9V/~1.01 A) from the original 18V/1.2Ah. My other battery isn’t much better (11.35V/~1.05A), so it’s time to get new batteries. The batteries are bad enough I went to use it and it was struggling with removing a screw.
I am looking at either the DCA2203C 20V kit (~$100) or buying a set of knockoff NiMh batteries (much cheaper) since both of them are pretty much shot. My charger can handle it since I have the 116 and not the 115. My concern is how long will they last compared to the NiCd packs becuase there are almost no vendors making clone NiCd batteries - not that you’d want them.
Has anyone worked with these knockoff batteries and are they worth the money? The high cost of the lithium kit makes it harder to justify piecemeal, but what does make sense is a new drill (~$100) and a DCA1820 ($35) - which will keep the DC970 in service with good batteries. The cheapest set I found that’s 3600mAh for $28 ($14/battery).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Typically these types of drills are sold with a NiCAD battery. NiMh is basically a newer version of NiCaD which you can replace with because NiMh will usually have a higher capacity and therefore more runtime. If you have a local Batteries Plus Bulbs, they may be able to rebuild the battery and replace all of the cells. They still use NiCaD but they’ll have a higher capacity than OEM.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'll have to call and see, but if I remember correctly the one closest does not.
さんによる
コメントを追加
I still use knock offs from ebay ML:DC9096 they fit they last for about a year and cost around 35 bucks for a pair for my Dewalt DC970
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 27
今までの合計 934
