メインコンテンツにスキップ
Ice maker won't fill with water
I just replaced my water supply line between the control valve and water filter on my Kenmore Elite refrigerator. I have good pressure and can dispense water with no problem. However, no water is dispensing to the ice maker. It worked fine before replacing the water line, and the ice maker is turned on. What could the problem be?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Hi,
What is the model number of the refrigerator?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Here are some situations that can cause no water to ice maker. Starting with the most common.
A wire came off the water inlet valve.
A failed water inlet valve.
The ice maker is turned off
Tempature at ice maker isn’t below 9*f
Air in the water line
The ice maker hasn’t had enough time to cycle
A problem in the ice maker
The water line to ice maker froze.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Mark T. さん、ありがとうございました!
統計データ:
過去 24時間: 15
過去 7 日: 58
過去 30 日: 232
今までの合計 4,324
