Why is my Chromebook has no Display
(Black Screen Display)
Hi,
You have given the model number of a WWAN card so that the laptop can access 3G phone networks.
Did you try connecting an external monitor?
If the laptop has a HDMI port, even a TV can be used as an external monitor, as long as it has HDMI inputs and you have a cable that can connect the two together.
Don't forget to press one of the keys on the top row (don't know which one in your situation as I don't know the laptop model - usually has a rectangle sort of symbol on it) to toggle the screen between the laptop, the external monitor and both on together.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 40
2 件のコメント
Hi,
What is the model number of the laptop?
Try connecting an external monitor to the laptop and check if there is a display showing on it.
jayeff さんによる
@jayeff hp hs3110 hspa+ notebook
marjonmaquez さんによる
