メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
AppleのPad 6のWi-Fiのみのモデルは2018年3月に発売されました。32GBと128GBの容量オプションがあります。9.7インチRetina ディスプレイと64ビットA10 fusionチップを搭載しています。
51の回答 すべてを表示
iPad 6 knocked 2 small components off during Tristar repair
Hi all,
I recently got an iPad 6th Gen for cheap as it didn’t turn on at all. I’ve been learning Microsoldering so wanted to take on the task! Straight away stuck a new battery in it, found that it did turn on however wouldn’t charge. I took multimeter readings from the charge port and i’m confident that the charge port isn’t the issue. Next point of call was to replace the Tristar chip, which i’ve now removed from the board. In doing so, I dislodged 2 small components next to tristar. Does anyone have any more info on what they are? Any components names/number would be ideal! There’s a lack of board schematics for this device so i’m a little in the dark. Yet to recieve the new chip, but want to nail down what i’ve knocked off first so i can sort that out.
Any info would be brilliant. Is this a component i could potentially pull from another board or not? Or even leave out all together?
Thanks again
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Essential Electronics Toolkit
Small Toolkit. Big Possibilities.
Shop Toolkits
Essential
Electronics
Toolkit
Shop Toolkits
1 件の回答
最も参考になった回答
You can check the iPad Air schematic/boardview to see if the components are configured the same way. If they are not, the we can clearly see on your picture that there are traces going from the empty pads to the Tristar pads so it should be easy to figure out as Tristar IC’s are pretty much compatible across most devices.
Just a quick suggestion when micro-soldering. If you have a camera on your microscope (or use an iPhone directly on the eyepiece), take pictures of the general area before removing IC’s or other components, especially when dealing with logic boards that don’t have full boardviews/schematics. That way, if something gets dislodged by accident, or you can’t remember the proper orientation, you can refer back to your picture.
この回答は役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Stewart Piper-Smith さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 21
