メインコンテンツにスキップ
モデル番号A2159、2019年7月に発売されたエントリーレベル13インチMacBook Proの改良版モデルです。カラーオプションはシルバー、スペースグレイ。
112回答 すべてを表示
How to replace keys
Someone unfortunately spilled a shot of a sugary drink onto the keyboard and a few of the keys have got sticky on the inside. I am able to remove the keys with no problem, but I want to be able to remove the hinges and cup to give it a thorough clean however the silicone dust protector is in the way. Has anyone had success on removing the hinges/ cup without the tearing this silicone film or have any advice on how to do this? Many thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
The newer butterfly keys are a real bear! I have yet to fix a key without breaking the cap! Here’s a good source 2019 keyboard parts
Frankly, I would see if Apple will replace the keyboard as the design is just not serviceable.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had some sticky keys after a minor spill, I took the logic board out, cleaned it etc, and while it was out, poured demineralised water (tilted away from and avoiding the battery connections), let it dry, then did the same with isopropyl alcohol. Left in a warm room to dry for a few days before re-inserting logic board. Sticky keyboard, including a key that had already been giving me issues prior to the spill, went away. Hope this helps someone!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jack Foley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 159
