メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhones apple comes onbut goes off again and reset don't work
Hi, i’m having trouble. My son done an update on this iphone 5s and it stopped half way and then went off. Now when i turn it on, the apple sign comes up and then goes out after 20 seconds. Hard reset don’t work as it still does the same and itunes can’t locate it now when i try to restore it
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You probably “soft bricked” your phone. If like you said the phone died in the middle of an update the software may have been corrupted causing the phone to not boot up correctly. You should still be able to put your phone into DFU mode and restore your device. Here are the steps listed on iFixit:
  1. Connect the device to a computer using a USB cable.
  2. Hold down both the Home button and Lock button.
  3. After 8 seconds, release the Lock button while continuing to hold down the Home button.
    • If the Apple logo appears, the Lock button was held down for too long.
  4. Nothing will be displayed on the screen when the device is in DFU mode. If open, iTunes will alert you that a device was detected in recovery mode.
    • If your device shows a screen telling you to connect the device to iTunes, retry these steps.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
i tried that but wasn't successful and when i take the phone off the power, the apple logo goes out and don't switch on
さんによる
コメントを追加
回答を追加する
lisamarie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 52
