メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
様々なテレビブランドとスタイルの修理ガイドならびにサポート
6730の回答 すべてを表示
Magnavox 42mf439b PC settings menu not available
I’m having an issue with my TV where I cannot adjust the screen to fix overscan. It clearly says in the manual that when connected to HDMI 1, it will work. However, my xbox is connected to hdmi 1 and it says it is not available. I already checked and there is no software upgrade available. I looked through the settings and I see nothing that would be locking out the settings I’m trying to change. Does anyone else know a solution that might work?
Yes I know my TV is old and I will most likely benefit from an upgrade, but a new tv that’s the same size (42ish inch) is a lot of money.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
@connor2003 I wonder if your TV expects a PC on HDMI 1 since that appears to be the dedicated PC input source.. Use a different HDMI port and let us know what you get.
この回答は役に立ちましたか?
スコア 0
コメント:
I've tried every port, it still does not work.
さんによる
Hi @connor2003 ,
Why are you trying to use the TV's PC settings menu to adjust the screen?
According to the manual on p.6;
HDMI Input
When using HDMI 1 input, you can enjoy this unit as a PC monitor "if your PC has DVI output terminal". (the inverted commas are my addition to the quote)
You are using an all HDMI connection so the TV is not expecting a PC on HDMI 1.
To my way of thinking it detects that a PC's DVI output has been converted into HDMI input. Perhaps because there is no audio from DVI. It has to be inputted separately There is an audio input jack on the back of the TV when using converted HDMI 1 from a PC which has DVI
If you have picture image problems try adjusting the TV screen display mode
Alternatively try adjusting the video output options from the XBox and check if that resolves the problem
さんによる
コメントを追加
Hello Conner on your remote there should be a picture size button, click it and change it to full and your problem should be fixed.
Have a nice day!
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Connor さん、ありがとうございました!
統計データを表示:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 59
今までの合計 898
