メインコンテンツにスキップ
モデル番号A1285/8もしくは16GB容量
204回答 すべてを表示
Can I still get music off my iPod if--
I was wondering if I can still get the music off my iPod. All that's left of the iPod is the logic board and battery. I've had it plugged into my computer but nothing has came up. Someone told me I probably have to reconnect the display and click wheel for it to work. I took it apart to replace the battery and accidentally tore the ribbon that connects to the click wheel so idk.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Jeremy Floyd you will need the click wheel. You can most likely disassemble everything outside the case to just get it to start up and be recognized if there is no other damage on it.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
When I plug up another iPod it starts right up without me using the click wheel or does the click wheel automatically send a signal through?
さんによる
It is possible that your iPod's firmware is checking for things that work etc. If it does not connect you know you have other issues with your logic board.
さんによる
コメントを追加
回答を追加する
Jeremy Floyd さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 25
