メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
678回答 すべてを表示
Front facing camera don't work after shell replacement
Hello,
I’ve got the same problem with an iphone 8 and an 8 plus.
The back was cracked so I change the shell, everything work fine except for the front facing camera.
I’ve tried hard reset, reinstall, DFU, repluging the flex cable, replacing the part and nothing seems to be working.
I’ve take caution when unplunging the flex cable, nothing seems to have moved under the foam covering.
Some got an idea ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
try swapping a know good front cam and back cam into the device, if that works then replace the old back cam and see if it still works and vice versa. had a few give me crap from time to time but maybe that helps.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Well, i've no problems with the back cam, they work like a charm.
And the front camera was working prior to the shell replacements.
And I've try with an known good, and it's doesn't work either.
さんによる
sounds like maybe a fpc connector. is your flash working? sounds like a stupid question but its all on the same circuit.
さんによる
コメントを追加
回答を追加する
freyjamir さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 28
