メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
677回答 すべてを表示
Display of iPhone 8 plus has gray stain
Hi there, so this is kind of a long story. I was replacing the ear speaker on my iphone 8 plus and there was a lot of dirt in the grills so i cleaned it with this liquid especially for the cleaning of electronics and unfortunately some of the liquid got trapped between the display. It was a lighter stain that you could see mostly on a white surface from a 40 degree angle. I then used a hairdryer to dry the liquid out and after that it went back a little bit but I noticed a gray stain, which was much more visible that the white stains. Is that just a coincidence or did I damage the display with the heat? Honestly the latter seems unlikely as it's only a small spot, not the whole side of the device I heated. But I googled and didn't find a cause. There are two photos attached, one from the top and one from a 40 degree angle where you can still see the white residue of the liquid. Also, at an angle the gray spot turns bright as you can see.
Thank you so much in advance :)
Best regards,
Adam
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Unfortunately, you got the spray between the multiple layers of the screen assembly. Depending on the composition of the spray, it may dry off and leave little to no residue (for example, mostly IPA) but if there are cleaners, it will probably leave a residue that will be visible.
Let it dry for a day or so to see if it gets noticeably better. If it doesn’t, you will have to replace the screen.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Thanks so much, it's noticeably better today so hopefully it'll disappear in a week or two. The solution is just rubbing alcohol in a gas can I think, so it should evaporate.
さんによる
Has the stain disappeared ?
さんによる
コメントを追加
I have the same problem after battery replacement ? Maybe it could be a gap by applying pressure to remove the screen with the suction cup ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
adamkuerth さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 281
