メインコンテンツにスキップ
Repair guides and support information for televisions manufactured by RCA.
181回答 すべてを表示
Why does my television has power but won't turn on?
Why does my RCA television has power , red light on , but won't turn on ?
Update (01/29/2020)
LED65G55R120Q . I've tried unplugging it , moving the cord to another plug , and left alone for a few hours.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Samora Choné remove the back cover from your TV. Get a multimeter and measure the power board to mainboard connector. You should have 5V STBY on your connector. If you do ( I am certain you do since your power light turns on) then the issue is most likely related to your main board. you do want to go ahead and post some good pictures of your boards with your QUESTION. That way we can see what you see and try to help you further.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Samora Choné さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 10
今までの合計 241
