メインコンテンツにスキップ
Intel Core i5 (5th Gen) 5200U / 2.2 GHz Max Turbo Speed 2.7 GHz Processor 6GB RAM, 1TB HDD 15.6" HD Display (1366x768) Resolution Integrated Intel HD 5500 Graphics
1回答 すべてを表示
Screen Upgrade (Higher Resolution LCD) for ASUS A555LB Laptop
Hi!
This probably won’t elicit a definite answer since this is about a specific part replacement, but I am still interested in your views or opinions (and why so).
I have a ASUS A555LB-XX410T laptop with a burnout spotty screen with the following specs: Screen Size 15.6 inch, Back Light LED, Connectors 40 Pin Socket, Resolutions & Inch 1366 x 768 (HD). This is the stock screen.
I am thinking of replacing it by ordering a different higher res screen ( FHD 2K 1920x1080 ) (pic below) with same dimensions and no. of pin connectors.
Question: will this work or will it be money gone down the drain?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Unless the video card / GPU / chipset supports it, waste of money.
Update (02/01/2020)
Reading online I found both the 940M and Intel 5500 supports 3840 x 2160 so you should be good to go with an upgrade, all else being equal (like you said, power, video connectors, etc).
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This laptop 15.6" at 1366 x 768 pixels (stock) with 5th gen Intel® Core™ i5 has the following: NGeForce® GT 940M and the onboard Intel HD Graphics 5500.
Do you think this is possible?
さんによる
コメントを追加
回答を追加する
raynerstuelgalid さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 251
