P1 and P2 Oxegen sensor codes
96 Pajero v6 petrol
Had my car scaned and showed these codes p1 and p2 Oxygen sensor is the any way I could fix and clear these myself?
cecildew yes you can replace the O2 sensors yourself. We would need to know your exact engine size and how you got those two diagnostic codes. you can clear the codes after your repair by disconnecting the battery ground cable for at least 20 seconds. Reconnect negative battery cable and recheck codes to confirm the repair.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 81
