メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AppleのiPad Miniタブレットの最新モデルは2019年3月に発売さました。A12Bionic SoCとアップデートされたTrue ToneのRetinaディスプレイが搭載されており、Pencil対応モデルです。
Delay in start charging ipad
Recently I bought an iPad mini 5, it works perfectly fine and keep battery very well but when I want to charge it when I plug it into the charger it sometimes take a few seconds (like 4-8 seconds) to start charging and I have to mention that I use Ipad’s original charger and cable and I also used anker power bank also my iPhone charge but I still have this problem.
Any one has experienced it? and anyone knows is it serious problem and is it may damage my iPad?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
7件の回答
最も参考になった回答
Exact same issue here on the iPad Pro 2020: can vary between 10 seconds to over a minute! And that’s with the official USB-C charging cable and fast-charge plug that came with the device
Curiously, using an old iPhone adaptor and USB to USB-C starts charging the same device immediately
And likewise: the official cable and charger are recognised immediately if the unit is powered off
Bizarre, very basic, issue
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I also have this problem, I think it’s an issue in iOS/PadOS as I’ve seen iPhones also do this is some versions of iOS.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I am currently going through this issue. I have tested on Apple branded and other brands of charging wires and ports but issue remains. I’ve contacted Apple and I got my replacement today. Issue is also on the replacement.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Maybe its an issue with many ipad minis, mine does the same
さんによる
コメントを追加
My new ipad mini is always have this same issue :( whats wrong :( do you think this is an ios problem?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Ipad mini 5 also has the same problem. Everything is perfectly fine but still it is anoying
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine also does the same sometimes it takes 15 seconds, no delays when it’s powered off though
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You should turn off your device before start charging..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
navid arbab さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 45
今までの合計 2,489
