Hover-1 pioneer doesn't charge.The charger light is always green. help
Recently bought the Pioneer scooter and it does not charge. The light on the charger remains green. What can I do?
i had same problem i wiggled it so it was in the sweet spot 4 red. my positve connection had rattled loose. i removed charging port from inside deck and sautered connection..or u replace
このアンサーは役に立ちましたか?
It is generally not recommended to attempt to add voltage to a dead battery to get a charger to recognize it. This is because a dead battery is likely dead for a reason - it has lost its ability to hold a charge due to internal damage or chemical changes. Attempting to force the battery to take a charge by adding voltage can be dangerous and may result in further damage to the battery, or even cause it to explode.
If you are having trouble getting a charger to recognize a dead battery, there are a few things you can try instead:
Overall, it is important to exercise caution when dealing with dead batteries and to always follow the manufacturer's instructions for charging and maintaining them.
If you can add a charge directly to the battery for a few minutes and then restore the battery, and use the OEM charger and it should recognize the battery and start charging
このアンサーは役に立ちましたか?
Your answers are bullshit
Battery’s dead get any battery that works put wire any length of wire ut one positive terminal of battery that works even car battery computer battery drill battery any battery as long as it has charge and fasten anyway you can other end of wire from positive working battery and then to none working battery do same with negative wire from working too none working leave 10 mins and now the dead battery thats either showing green when you charge or not charging has enough charge from milking charge is now recognised by charger
And if you have no charger find same voltage and amp out put or close to whater your charging red and black positive and negative
Brown positive and blue negative
Both wires black the black wire with writing or white lines is positive and plain black negative
Ok charge but only while your there if unattended don’t put near anything that can burn prefer wait while charging put on something that can’t burn concrete floor or stove just think nowhere it can light other stuff example wooden chair or carpet they can burn be smart
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 41
今までの合計 815
