メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
2014年9月19日に発売されたこのiPhoneは4.7インチのスクリーンサイズでiPhone 6 Plusの縮小版です。
5139の回答 すべてを表示
No service after housing replacement?
Hey there. Just did a housing replacement. Everything works brilliantly, but the phone just says no service when I put a SIM in. Everything else is fine.
Any ideas?
Cheers.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Is this an original housing or an aftermarket one? The antennas are embedded into the housing so a poor quality replacement housing will potentially cause issues. The other possibility is that the screws are mismatched. Double check your work by following this guide.
After you have eliminated antennae or network locks as the possible culprit, searching issues on the iPhone 6 are usually related to the baseband IC. The baseband IC is very sensitive, just like the Touch IC's on the 6 Plus; it also suffers from poor quality traces and pads.
 Go to your phone’s dialing keypad and dial *#06#. You should see the IMEI displayed.
If the IMEI is not displayed, the Baseband IC has to be reballed and two small copper traces (U1/V1) have to be rebuilt and solidified.
この回答は役に立ちましたか?
スコア 2
コメント:
Thanks, will try those. The thing I noticed is that some of the logic board was actually unclipped, and I couldn't clip it back on. https://imgur.com/a/gNe2RjN
さんによる
Also, does it matter if the antenna interconnect is not properly connected? Mine was a bit bent so I didn't fit it properly.
さんによる
Do you mean this?
That is the 5GHz antenna. Normally there are four small connectors on the logic board (and likewise on the flex).
さんによる
Yes!! That is it. Is this the issue?
さんによる
I should have pointed out it's the 5GHz WiFi antenna. This has nothing to do with your SIM card or cellular service.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Rafay Siddiqui さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 65
